No, you looked at the wrong place. You have to look in
C:\ProgramData\PTC\Mathcad Prime
to find the .config file(s), NOT in Program Files.
Note that C:\ProgramData is a hidden directory, but you can navigate there by entering the pathname in Windows Explorer.
One level deeper, in
C:\ProgramData\PTC\Mathcad Prime\Logs
you will find the log files, but they (most probably) will not help you.
Hi @MV_12915413
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Did you remove and then reinstall or just do a reinstall over the first install?
Is the spalsh screen coming up or not even that far?
Check the log files for anything that it may record there about missing files, etc.
I tried both ways reinstalling it fully and on top of the first (Basically deleted the mathcad folder fully and installed it again)
Well, even the splash screen is not coming up
P.s. under which folder are the log files?
I am not a MathCAD user, but I looked in the install folder and didn't see any from the couple of times I have run it.
I would delete the installation folder again and then use Regedit and remove any references to the MathCAD installation folder before doing another install. I do this on my Windchill installs to be sure there is nothing lurking from a prior install. Also look in c:\users\<your_username>\appdata folders for some files that MathCAD may have installed there. Appdata is a hidden folder by default.
Tried two times, not working unfortunately
P.s. I remembered that i was trying Mathcad 9 a few days ago and it was working, so i guess the problem is in Mathcad 10 itself
Lookin C:\programdata\ptc
And further down.
You'll find log files and a .config file. The .config file you can delete and then retry running prime 10.
(The .config file can become corrupt. Prime will recreate it if it is missing)
Hello!
I looked through the program files -->PTC--> Mathcad prime 10
And then tried to do the search function for ".config", and there is kinda no file with such a name (only these 3 files)
Thank you, worked out !
It feels that it bugged somwhere, but thanks one more time
P.s. now have to send few hw😀
Try the following:
1. Create a backup (or just archive) of the config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\)
2. Delete the current config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\)
3. Run Mathcad Prime again
