Hello, I tried to download Mathcad Prime 7 but in the installationassistent the status of the application is "not permitted". How can I avoid this?
Do you have a license for Prime 7 (or 8 or 9)?
(Then you should be able to download the installation source from here.)
Do you have Prime 8 or 9 already installed on your PC?
(You can install multiple versions of Prime on the same computer, but you can only install them in sequential order, from lower to higher version).
