I have the professional version of Mathcad Prime 8. However, when I remote login to my PC Mathcad Prime runs in express mode (feature limited + has water mark across the page).
Is there a work around for this?
I did notice that if I happen to have opened Mathcad Prime at my PC desk, and then remote login at a later time, Mathcad runs normally (no feature limitations or watermarks). I just have to remember to start Mathcad Prime first - if I plan to remote login later.
Maybe there's a better way?
Article - "[Knowledge Hub] Working remotely with Creo / Mathcad": https://www.ptc.com/en/support/article/CS322270
With a node locked license it seems it is not possible to remote login and checkout a license.
"Is it possible to use Mathcad through the remote desktop or the terminal service": https://www.ptc.com/en/support/article/CS32731
I believe I have the so called node locked license.
