Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hello PTC Team, I installed Mathcad prime 9.0 student edition, also made the licensing and now if I start up Mathcad the loading window opens, then it closes and the program doesn’t start up.
