Plotted values do not match vector-printed values
motan
3-Newcomer
I am using Mathcad Release 15.0 and DatecodeN/A
Automatic scaled values on plot are different from the computed ones (when listed as a vector).
None
It plots in system units unless you specify as above.
LucMeekes
(To:motan)
"Here are the errors that I faced
None "
With no errors, there's nothing to complain about, is there?
If there is a problem, please show it clearly. Attach the worksheet and indicate the problem.
motan
3-Newcomer
(To:LucMeekes)
Hi.
Thank you for the prompt reply.
My understanding when was asked about "error"  is to provide some message generated by Mathcad, which does not exist.
In fact, what I am looking for is an explanation on why on the plot the values (magnitude: E7) do not match the vector-printed values (magnitude E4),
please see enclosed.
Thank you very much!
