"Here are the errors that I faced
None "
With no errors, there's nothing to complain about, is there?
If there is a problem, please show it clearly. Attach the worksheet and indicate the problem.
Hi.
Thank you for the prompt reply.
My understanding when was asked about "error" is to provide some message generated by Mathcad, which does not exist.
In fact, what I am looking for is an explanation on why on the plot the values (magnitude: E7) do not match the vector-printed values (magnitude E4),
please see enclosed.
It plots in system units unless you specify as above.
Thank you very much!
