Problem with units in Combo-Box
AK_9934504
7-Bedrock
I am using Mathcad Prime 7.0 7.0.0.0
I need help to solve a problem with error in Combo-box. When I try to set up units K/W or m/s in dropdown input menubox after that block turns red. How could I to use such units as K/W or m/s such as input values? I guess that is problem in using input dropbox. I couldnt find any information about solving this problem in MathCad help.
Blok turns red without error message.
@LucMeekes thx u a lot. While I was waiting I figured it out myself. The solution completely coincided with the one described in the topic you linked. But it seems this is bad way. Developers should pay attention to this.
Also they should pay attention on positioning of Combo-Box fields. I cant place this fields in straight vertical line. See below
LucMeekes
(To:AK_9934504)
