Text Box - Text Formatting - Numbered Lists
JeromeHatlewick
I am using Mathcad Prime Release 10.0 and Datecode10.0.0.0
I am working on a design sheet and as part of the sheet I am including a design methodology write-up. I am using a numbered list and the write-up is too large to fit on one page. I split the write-up over 2 pages but the numbered list restarted at 1. on the second page of the list. Is it possible to set a number value for the numbered list on the second page that continues the list from the first page?
None
Use Microsoft Word or other word processing software and with a bit of experimentation and cut and paste you will get what is needed.
You also get better sub-numbering like 1,2,6 etc.
Thank you.  I copied the text from the second page of the list into Microsoft Word and changed the number value in the list.  When I copied it back into Mathcad Prime it stayed with the numbering.
Happy New Year!
