Dear Sir/Madam,
We need assistance with installing Mathcad on a new PC.
We currently have:
2 licenses for Mathcad 14 (CD-based)
1 license for Mathcad 15 (CD-based)
However, we are encountering errors during installation.
Please guide us on how to properly install these versions on a new system, and help resolve the installation issues.
Thank you for your support.
Sincerely,
Nisa
accounts@smsce.com.sg
it@smsce.com.sg
As a start - one would need
Host Operating System (OS): What is the main OS running the computer? (e.g., Windows 11, macOS Sonoma, Ubuntu Linux).
Installation Method: Is the installer running directly on Windows, or via a virtual tool?
If virtual, state the specific tool: Wine, CrossOver, Parallels (with Windows OS), VirtualBox (with Windows OS), etc.
System Architecture: Is the computer 64-bit or 32-bit?
Exact Error Message: Quote the entire error text, including any codes (e.g., "Error 1324," "MSXML 4.0 not found," "Licensing failed (403)").
Error Timing: When does the error appear? (e.g., Installer launch, Prerequisite check, License setup, End of file copy).
The versions you have are no longer supported. Ideally you should get in touch with PTC. This is a user forum and as such installation issues are best handled by the developers of the software.
Thank you for the reply.
We saved the cd installation file in usb.
Windows 11 64 bit
Attached error
Try Help
https://community.ptc.com/t5/Mathcad-Installation/Invalid-Host/m-p/733519
or
The error, "The host id of this system does not match the host id specified in the license file" 1, is expected when transferring a node-locked license to a new physical machine, as the unique hardware address (Host ID or MAC address) has permanently changed.4
The only required solution is to obtain a new license file from PTC bound to the new computer's ID.
You must first determine the exact 12-digit hexadecimal address (Host ID) of your new PC that PTC's licensing system recognizes as valid. Native Windows commands are often insufficient; the proprietary PTC utility is the most reliable method.6
Action 1.1: Use the PTC HostID Utility (cpu_id.exe)
Use the new Host ID and your original product information to request a new license file. This process formally transfers the software entitlement to the new machine.5
Action 2.1: Obtain New License File
Once the new license file is received, you must tell the Mathcad software where to find it.
Action 3.1: Apply the License
Hello @Nisa_SMSCE,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
