I need to converter the worksheet which I created in Matchad prime 4 to Matchad prime 7 but the XMCD,MCD converter tab in input/output section is disabled in prime7.
Could you please help to solve this issue.
BR,
Kishore
It is not necessary to convert a file from Prime 4 to Prime 7.
Just open the file in Prime 7.
Cheers
Terry
Cheers
Terry
