As stated in article CS22570:
Validation: The 4 examples have all converted well.
With regards, M.
What version of Mathcad created the *.MCD files?
Prime 7 comes with a converter that converts Mathcad to Prime but you need to check the version of Mathcad is not too early?
To test this upload one of the mcd files and the converter can be tried and we can pdf the results so you can see it.
Cheers
Terry
Hi
The first line of the *.mcd has a code.
.MCAD 304020000 1 372 202 0
but I don't know how to decipher the code.
Best to try a file for you.
Cheers
Terry
If you don't have many files, you can attach them all in one archive here.
With regards, M.
A .MCAD304 file is created by Mathcad (not Prime!) version 6.
I get the specific code 304020000 when saving from Mathcad 11 down to 6.
A file saved from native Mathcad 6 has 304000000.
Is it true that the Prime7 converter might not handle certain .mcd files because they're too 'old'?
I'd be curious to know. Attached are a few files to try out.
