my converted file wont run
GA_10578198
Hi my old files needed to be converted from PTC and MCD fromat to XMCD format. the result looks broadly similar, but i cant get it to run. Would it possible for you have a look at the worksheet and see if you can find out whats gone wrong in the conversion, please.
Greg
7 REPLIES 7
Add the old file to the post?
Cheers
Terry
Hi thanks so much for getting back to me so quickly.
As requested is the old file. I think its got a bit dusty over time..
Best Wishes
Greg
Hi Greg
Still no posted file:
You can also put the files in one archive beforehand.
the file is attached to my previous post FNC1.MCD
ill attach it again here.
my thanks once again
There are no attachments in your message.
LucMeekes
(To:GA_10578198)
We don't see the file attached.
You better use the web forum at: https://community.ptc.com/t5/Mathcad-Installation/my-converted-file-wont-run/m-p/854518#M2887
