Transferring Mathcad License from Existing Host ID to New Host ID
This process yields the same result as before, the prompt just tells me I don't have enough licenses.
You can find the answer for this issue in the following thread earlier - "Reached the maximum number of license request": https://community.ptc.com/t5/Mathcad/Reached-the-maximum-number-of-license-request/td-p/704852
The link provided leads the the same screen as shown above. Will I need to charge back the product? I can't find any way to call support directly. I just need to use the product I purchased, and the website is bouncing me around the same 4 screens.
the USA website you linked is a 404. The phone number you linked is unavailable. Please provide a phone number that works.
Well, the Support pages are outside of things I have control of (or knowledge of). I didn't know that mathcad_contacts page still exists; it probably shouldn't if the American number is incorrect.
This number, as far as I know, is right: https://www.mathcad.com/en/support/customer-support-guide/contact/contact-by-phone-americas
Edit: Oh, I see you've tried calling that number. ...Maybe today will be better.
I have the exact same issue you did here, how did you end up solving it?
this issue has not been resolved, support is unresponsive and I'm considering a charge back.
You should request for a license manually by providing your Mathcad product code and physical address of Ethernet adapter using the following web case logger:
http://support.ptc.com/support/mathcad_supportCenterSingleUser.htm
The license file will be sent via E-mail.
Dhiraj Patil
