Hello everyone,
I attached work sheet with PRIME7.
I can not use any units in 3D plot.
And I canceled the units of valuables, but also I can not have any plots.
Is this correct ?
Auto labeling changed my result. Use new attached sheet.
3D PLOT without units by PRIME7.
Hello ttokoro san,
I have following message, and can not plot.
No data found. Try changing the axis range or the axis formula.
ttokoro san
I can not find attached file.
Thank you.
fff(x,y) and f[x,y Prime 7 file attached.
ttokoro san
Thank you for your response.
