3D PLOT with units by PRIME7
ssato
Hello everyone,
I attached work sheet with PRIME7.
I can not use any units in 3D plot.
And I canceled the units of valuables, but also I can not have any plots.
Is this correct ?
1 ACCEPTED SOLUTION
ttokoro
(To:ssato)
Auto labeling changed my result. Use new attached sheet.
6 REPLIES 6
ttokoro
(To:ssato)
3D PLOT without units by PRIME7.
ssato
(To:ttokoro)
Hello ttokoro san,
I have following message, and can not plot.
No data found. Try changing the axis range or the axis formula.
ttokoro
(To:ssato)
ssato
(To:ttokoro)
ttokoro san
I can not find attached file.
Thank you.
ttokoro
(To:ssato)
fff(x,y)   and f[x,y   Prime 7 file attached.
ssato
(To:ssato)
ttokoro san
Thank you for your response.
