Does prime 2.0 not allow unit in the variable for x and y axis??
suppose I have
f(x,y) := x*y/10 m^2 + 100 m^2
and the unit in x and y are both meter^2
then I cannot plot f(x,y) in 3d plot? Nor can I use it in creatmeash? not even with the matrix builtin function because it only take unitless value for the range ???? What good is 2.0 then...
I just hate the process of dividing all my variables by their units ........
If I plot the function you show in Prime 2.0 it plots fine, with units. Please post a worksheet showing the problem.
Attached is the worksheet...I do not like how the 3D graph on the lower left does not work...check the last two page
I have to manually convert the function into one with unitless independent variable. I wish I can skip this converting step.
BTW I cannot plot the function I showed earlier in 3Dplot either.. I cannot attach any unit to the independent variable...
I use in this case not a Surface plot but a set of curves on x-y Plot.
