In reference and reply to another visit ... for general use.
Ask the "unit system specialists" to plug your unit [make it work].
Typical demo
jmG
...added another tool.
Assuming the function is an "Engineering formula" already in the appropriate unit system, and you want to display ... then you can't use the Mathcad built-in system, Create a "User Unary UnitResult" [green].
jmG
...Yep,
this community does not sequence the same work sheet like Akiva:
*.mcd
*.mcd(1)
*.mcd(2) ... and so on.
jmG
