Algorithm for calculating built-up steel columns ?
ptc-5090961
Hi, I'm structural engineer. Maybe anyone of you has an algorithm for calculating built-up steel columns (not necessarily in mathcad but it would be advantage) ? Would be grateful.
Hi Jonas,
Please find in attachment the following article:
1. "Detailed Design of Built-up Columns".
2. "Design of built-up columns".
And check this course of lecture (ESDEP Course):
"Lecture 7.6: Built-up Columns": http://www.fgg.uni-lj.si/kmk/esdep/master/wg07/l0600.htm
"Course Contents": http://www.fgg.uni-lj.si/kmk/esdep/master/wg07/toc.htm
