Since it is no longer possible to install MATHCAD 15 on my new PC, even though I have a perpetual license, I am looking for a software that is up to its standard. I was offered MAPLE FOLW...What do you think?
If you try these steps, then maybe you will have some success - or you can post specific questions as they arise. Hope it works.
setup.exe file to start the installation.Mathcad 15 licensing sometimes ties to the physical (MAC) address of a network card. To emulate or spoof this address on a different PC, follow these steps:
ipconfig /all and press Enter.00-14-22-01-23-45).001422012345).This configuration should enable Mathcad 15 to recognize the licensed MAC address and function properly.
Well according to Maple Flow (Great!)
How Maple Flow Compares to Mathcad® - Maplesoft
According to this forum (??)
How Maple Flow Compares to Mathcad - PTC Community
I believe you can use MATHCAD 15 on new PC in case that you are allowed to install virtual machine with appropriate operating system and MATHCAD 15 installation inside this virtual machine.
Hi! Thanks for replying. I don't know how to do this, I need a procedure to do this.
Search - how to acquire and install a VM with older windows OS
Could use VMware, Hyper-V and the relevant OS
if you never met term virtual machine then I can't help you (I apologize for it). One must have some knowledge to create and use virtual machine.
Thank you, but if the problem is the license, what do I do with the virtual machine? Maybe you meant that MATHCAD 15 does not run in a Win 11 environment so that this virtual machine is needed?
please note that:
I am 77 years old, I have been an engineer since 77 and a professor of electronics and related subjects, but retired since 2011. In 72 my first approach to the computer. Then in one way or another I programmed using various languages, lastly Visual C++ which I used at the same time as Mathcad from the first versions to the 15th. I know the physics of LASER and the related theory, including Quantum Mechanics. For some time I have been creating something related to electrical engineering with active and non-active networks and also I try to give correct answers to the users of "Electrical Engineering of the Stack Exchange". I find difficulty with the amount of RAM on my old SONY Vaio which is only 6 GB. This new computer has 32 GB but I have this installation problem. So if you tell me how to do it in detail, I can proceed with my activity, otherwise I have to settle for the old computer and use Maple Flow 2024 on this new one. Thank you in advance. Regards.
I'm sorry, but I'm not going to continue this discussion. Do what suits you best.
I have always accepted your advice for decades. Now with my previous answer with which I only wanted to define what my knowledge and skills are, nevertheless, I must have struck your sensitivity in some way but I do not understand how, I have never insulted people. Regards
nothing happened. It's just that my native language is not English, so sometimes my answer may seem strange.
Thanks a lot for the directions, But if there is no certainty in the success of the installation, I prefer not to even try. Thanks anyway.
Give it a shot - you’ll enjoy doing it. Next you will be doing WineHQ on Linux.
Since when was there certainty of success in any venture? 🙂
Even the most reliable of aircraft can suffer an engine failure just past the runway threshold after takeoff (or encounter wind shear and lose valuable knots (km/h)!). Yet, still, the prospect does not stop (many) pilots from taking to the skies.
And even the most reliable and capable of computers can suffer a hardware glitch or become obsolescent. Yet, still, we switch them on ...
Stuart
"the most reliable of" should, of course, read "the hitherto most reliable of ". 😁
Thank you again for your reply.
Unfortunately, my new computer has Windows 11 installed and at point 3.2.2 and 3.2.3, I can't find what you describe, the MAC isn't there. What to do?
https://www.youtube.com/watch?v=8CD7oJ6ak-Q&pp=ygUdY2hhbmdlIG1hYyBhZGRyZXNzIHdpbmRvd3MgMTE%3D
If you can't access it, it seems the IT administrator (if you have one) has disabled access to it and will need a login with administrative rights. or
Warning: Modifying the registry can be risky. Ensure you back it up before proceeding.
Open Registry Editor:
Win + R, type regedit, and press Enter.Locate the Network Adapter Registry Key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002BE10318}Find Your Network Adapter:
{4D36E972...} key, you’ll see numbered subkeys (e.g., 0001, 0002).Add or Modify the NetworkAddress Entry:
NetworkAddress.NetworkAddress and enter a new MAC address (12 hexadecimal characters, e.g., 02A1B2C3D4E5).
02) should indicate a locally administered address (e.g., 02, 06, 0A, or 0E).Apply the Changes:
This method is more user-friendly and avoids manual registry edits.
Download and Install Technetium MAC Address Changer:
Run the Application:
Select Your Network Adapter:
Set a New MAC Address:
02A1B2C3D4E5).
Apply Changes:
