Arrays, I can't get the two terms to add up. i can get the results for each term
SFares
I can't get the two terms to add up. i can get the results individually. Attached is Mathcad 15 sheet. Thanks
(To:SFares)
Avoid inline evaluations.
Define the variable and then evaluate it in a separate region:
(To:SFares)
SFares
(To:Werner_E)
Thank you, Werner!
ttokoro
(To:SFares)
Prime 9 converted.
SFares
(To:ttokoro)
Thank you, ttokoro!
