I am using Mathcad15 and new to it.
i need to feed typically 4 basic values into mathcad and get result back. i have more than 160 sheets to work.
Am trying to automate the values logged in excel to feed in Mathcad as different files saving as PDF well.
Can anyone suggest or confirm this one is workable.
I tried few times but end up with error loading page. Provided the code below.
Your excel file has two cells filled:
A1 contains OD
B1 contains 100
Your script takes these two values and assigns them to var1 and var2 respectively.
Then it attempts to bind the two values to the real parts of Mathcad variables A and B respectively.
Since Var1's value is OD, which is a string, this swill fail.
Also your script executes a calculation and saves the sheet, but produces no .pdf output...
You say you have 160+ sheets to work...
Do they all have the same calculation, and are you attempting to automate executing that same calculation on the basis of 4 variables that take on different values in each of the 160+ sheets? Then it's easier to put the 160+ different sets of 4 variables in a matrix (in Excel if you insist), and have Mathcad calculate the results in one go (and export the results to an excel sheet if necessary).
Please explain your scenario better.
