I am thinking of upgrading my Alien 17 R4 laptop (intel(R) Core(TM) i7-7820Hk CPU 2.9GHz, 32GB RAM ). I would appreciate any thoughts, guidance or recent experience on selecting a laptop/desktop PC suitable for running parallel instances of Prime - where each instance is running a large numerically intensive programme.
Many thanks
GeoffD
That would be the PC with the most CPU-cores, the highest CPU clock rate AND the largest amount of RAM memory.
Thanks for the quick reply. My quest is to identify which PC is the most powerful, and most suited, to running complex, heavy-duty, memory-intensive Prime worksheets.
Thanks, Luc for the advice.
It would be good to hear of any domain-specific experience, where Prime's performance on specific machine configurations might have been benchmarked. The way that Prime operates might not be able to fully leverage a machine with the best of the best - giving no better response than a lesser-grade/cheaper machine.
Regards
GeoffD
After agonizing over the different processor options and without finding any metrics on Prime's performance on different machines, I ended up doing pretty much what you suggested - Success 🙂
