Binary Distillation with the McCabe - Thiele Method
TudorMarin
Description:
A propane-pentane feed at 10 bar is to be separated in a multistage distillation unit to a required purity of both components. This worksheet will calculate the required number of theoretical stages required.  Data describing propane-pentane equilibrium composition is supplied.
0 REPLIES 0
