Can anybody help me recovering this mathcad file? It wont open.
The attached should be your file, or what was recoverable from it.
It is saved as Prime 4.
Note that any text strings and pictures are not recovered.
The file is corrupt, but the worksheet part of it may be still intact.
It takes some effort to get it out....
Hi LucMeekes
Thanks a lot for your reply. I could not recover it my self so i just deleted the file.
Do you have a backup, or a print-out from which you can recreate the worksheet?
No i just had the file. I have made all my calculations again. But thanks a lot for answer and that you take your time to help.
Mikki
