There is one more calculation to be performed based on the interperolated values. However the value of appears to change after the calculation of
. I do not understand why? Any suggestions.
Thanks.
Function get_k() is defined twice. Value changes when you define the second function.
Cheers
Terry
Cheers
Terry
Thank you very much Terry.
