Can somebody help me to convert this file to MathCad 1.0 Prime file type?
You can find Mathcad 15.0 30-Day Free Trial here: http://www.ptc.com/products/mathcad/mathcad-15-0/free-trial.htm
Why can you not convert it?
Mike
Because I am testing a trial version of MadCad Prime 1.0, which comes without this option.
Thanks Mike, but it says that "this type of file is not supported" ?????????
Thought that might be the case because I only have Prime 2.0 on this machine.
Mike
If you don't mind me asking, why exactly do you want the worksheet in Prime. I have just converted it and it looks untidy and the solve blocks have errors.
Mike
I have used MathCad 14 before, thus I was planning to buy the new Prime version. But if it is having troubles, I will try to buy the 14 version, because I have a lot ot files from the old version that I need to use.
Prime is the future of Mathcad, but has a long way to go before it has all the features that M15 & M14 has.
Saying that, if you purchase Mathcad Prime 1.0, you get a copy of Mathcad 15 free. Might be worthwhile because that way you also get to see PTC's new product and familiarize yourself with it.
Mike
The current version is 15, but that will run all your 14 files fine,
If you have a lot of files written in version 14 there is a very good chance that some (and possibly many) of them will not work in Prime, even after conversion. It may be possible to fix some of them, but it's also possible that some cannot be fixed. Currently Prime is missing too many features (that applies to Prime 2.0, not just 1.0)
Thanks !
It was the final solution. Thanks
No problem.
