I am unable to plot multiple traces in Mathcad prime 9.0 when first defining a chart component from the menu ribbon. For example, I selected chart component from the menu ribbon and defined an X1:=x, Y1:=cos(x) and Y2:=sin(x) but only the Y1 trace appears in the plot.
I still had Mathcad 8 on my computer and was able to plot multiple traces.
I then cut and paste the multiple trace chart component from 8 to 9 and it worked in 9.
It seems like the multiple traces just doesn't work when I start a graph from the menu in 9. What's going on? Any suggestions on how to fix the problem in Mathcad 9.0? I tried exiting the program and rebooting but I cannot get multiple traces in chart components when starting from the menu ribbon. I can only get it to work if I copy from an existing multiple trace chart component. A pdf and the mathcad documents are attached.
Thank you!!. First time using chart components and I'm still getting used to it.
If you use X[1 instead of X, you must add X[2.
