Changing MathCAD Prime 10 language
TM_11561646
2-Explorer
I cannot find any language option in the menu. Anybody had this problem?
(To:TM_11561646)
Unfortunately this is only possibly by adding a command line switch when calling the program.
It may look like this:
"C:\Program Files\PTC\Mathcad Prime 10.0.0.0\MathcadPrime.exe" /culture:en-US
You may create a desktop icon  for the program and add that switch in the 'target' field.
Supported languages are:
Supported languages Command Argument
English en-US
French fr-FR
German de-DE
Italian it-IT
Japanese ja-JP
Korean ko-KO
Russian ru-RU
Spanish es-ES
Simplified Chinese zh-CN
Traditional Chinese zh-TW
BUT ... this will not affect Prime files you open by double clicking the file, like files you find attached in a thread here in the forum.
To work for theses files, too, you would have to fiddle around in the registry!
Its very silly and annoying that PTC has not implemented an easier option for changing the language from within the program itself and storing it in a config file, so it will be in effect no matter which way the program is started.
