To all
I am dealing with a formula and I am hoping that the more mathematically inclined among you might be able to clarify something for me.
On the attached mcad 15 file there is a formula for a mode indicator function. I am still trying to source the original reference but in the meantime I thought I ask the question.
Could anyone tell me how the sum on the numerator works? Is the formula saying that one has to sum over the entire vector?
Thanks in advance
I would see it that way
Actually the absolute value in the nominator isn't necessary as here a real number is squared.
Using vectorization you could also code it in Mathcad like this
The other formula (Breitbach) yields a different result
Thanks for the input. I cannot find any paper/text, etc from the quoted "reference". Never mind
The formula yields 1 number. In reality the complex vector is frequency dependant. That is each row is a value at a given frequency
If I got this right if an entry in the complex vector is (near) to imaginary then the MIF should drop (close to zero, drop to a minimum) (at a given frequency)
So one should be able to plot a MIF value at each frequency
Anyway you have answered my original question
Would this help
https://pdfcoffee.com/ecss-e-st-32-11c31july2008-pdf-free.html
See 3.2.33
Maybe this paper can be of help, Formula (6) seems to correspond
http://papers.vibetech.com/Paper35-MMIF.pdf
But I have to state that I'm way outside my comfort zone here and have no knowledge of the underlying subject matter.
yes that's where the formula I pasted in the mcad file is coming - the ecss reference. This one yields 1 number
The 2nd ref I am have and is for the Multivariate MIF - uses the H matrix and is an eigenvalue problem ? (or maybe I am confuses with the Complex MIF (CMIF) !)
of interest: 546802.pdf (hindawi.com)
equation 8
