I use MathCad about once a month, and recently when I click the icon, nothing happens. I am running version 14 on Win 7. I don't recall any major changes to my computer in the intervening time other than installing some compilers.
I finally ran the MathCad remove feature from the install disk, and removed prior editions as well with the MS remove feature. (I have been using upgrades for about 15 years). I deleted any reference to MathCad/MathSoft from my program_files.
After reinstalling the product sucsessfully it still does not start. The only traces that I am aware of after the removal process were system registry keys. I usually avoid playing in this area but the temptation is to delete the regsitry keys for MathSoft and try to reinstall. Has anyone done this? Anything risky I should be aware of?
Fritz
What version of Mathcad 14 are you running?
Mike
My version is 14.0 M020
The last release Mathcad 14 - is M035. Try to update/install Mathcad 14 if you have the active maintenance.
P.S. Also see my response here: http://communities.ptc.com/message/167147#167147
Yes, but if you try it, you do so at your own risk. Create a Windows restore point AND a registry backup before you do it. You may also want to try cleaning the registry first with CCleaner (http://www.piriform.com/CCLEANER), which will also allow you to create a backup. I use CCleaner regularly, and I have never heard of anyone having a problem afterwards.
