Conversion of file
FDS
Conversion of file
Would someone be so kind to print the document "Easy Fit" of the latest blog into pdf format? Thank in advance!
MikeArmstrong
(To:FDS)
There you go.
Mike
9 REPLIES 9
MikeArmstrong
(To:FDS)
There you go.
Mike
FDS
(To:MikeArmstrong)
Thanks Mike, highly appreciated. Could you tell me whether clear.sym is a specific function for Prime or is there an alternative in MC15?
MikeArmstrong
(To:FDS)
From the help menu of Prime.
clear.sym(x, y, ...)—Clears variables x, y, ..., symbolically but not numerically.
Mike
VladimirN
(To:FDS)
FDS wrote:
... is a specific function for Prime or is there an alternative in MC15?
Yes, is a specific function only for Prime.
Certainly an improvement on M15
Mike
(To:VladimirN)
But clear.sym(x) does the very same in Prime as x:=x in Mathcad 15.
The real improvement in Prime is the clear(x) function, which clears x for numeric evaluation, too.
Werner
Werner
I suppose so, but at least it gives an indication of what Mathcad is doing to the reader. x:=x is not really self explanatory.
I agree that clear(x) is an improvement.
Mike
I agree that its not self explanatory, but  FDS was asking;  "Could you tell me whether clear.sym is a specific function for Prime or is there an alternative in MC15"
So yes, as a function its specific to Prime and, also, yes, there is an equivalent alternative in MC15.
Werner
FDS
(To:Werner_E)
Werner, thank you for your explanation. I always learn a lot from your comments in this collaboratory.
