Convert Mathcad 15 Template
ptc-4414777
Trying to import an .xmct template into Mathcad Prime 3 I got stuck because the xmcd button is grayed out.
It seems that I need a copy of Mathcad 15 to access that functionality.
Is there a way I can convert that template without the need of installing the old program version?
Thank you for your suggestions.
Chris
(To:ptc-4414777)
Here is the converted file. Guess it will need at least some reformatting.
(To:ptc-4414777)
Its true, you need a full install of Mathcad 15 to be able to convert leagcy sheets.
Another way is is to post the sheet here (if you can do that) and ask if someone can do it for you.
Because Prime lacks a lot of the features Mathcad 15 has, the conversion will work fine for very basic sheets only.
Werner, thanks for the clarification.
I'll give it a try with posting the file.
Can anybody give it a try?
Chris
(To:ptc-4414777)
That was very helpful, thanks. It looks as expected... (or at least what one can expect changing from a non page oriented format to an oriented one).
Thanks a lot
Chris
