Hi!
Can u convert this file, pleasse!
I can't convert them in Mathcad Prime option.
Thank you!
If you have Mathcad 15 and prime installed on the same PC you should be able to convert. Note that your Prime license entitles you to license Prime and Mathcad 15.
Success
Hi, can someone please convert this mathcad 15 to PTC Mathcad Prime 5.0.0.0
It's very important for me and i don't have that option on my prime
You can find the converted worksheet in attachment.
I see you assisted another person to convert a file. Would you mind doing the same for this one? I have Prime 2.0 but I can't run Mathcad which I could probably install an older version for but Mathcad doesn't work on my newer Windows platform except in some emulator mode which I tried and it didn't work at least not for me.
Here you are. I hope it works.
The converter had the following messages:
1. The Data Import Wizard is not supported in the current version of PTC Mathcad. Your data was imported using a suitable File Access function. Unless specified, the accuracy of the results is not affected.
2.Plot labels are not supported in the current version of PTC Mathcad. Use text boxes to label your plot.
Hi @cici
For further files you can follow the below procedure to convert the files
Users can also launch the converter using one of the alternate options below
From <Mathcad_Prime_Install_Dir>\ WorkSheetConverter.exe
Select Add Worksheet > Select the desired worksheet/s to convert > Convert.
Note:- Each successful conversion creates a new worksheet with extension *.mcdx in the same folder as source file.The source worksheet is not modified.
Also, you can refer article CS22570 for more information.
Yep!
Thank You!
Hi, can someone help me by converting the file so I can open it in Mathcad Prime? My option to convert the file is also grayed out. thanks!!
Anyone who can help me convert the attached file. My Mathcad 15 license has expired 😞
Hi can someone help convert this file please.
thank you in advance!
Please find it in attachment.
Can someone please help convert this file?
Here goes.
You'll have to pay some attention to the units.
Could I please get someone to convert the attached files to Prime 8.0 for me? I have access to Prime through my institution; for some reason, the "XCMD / MCD Converter" is grayed out when I open Prime 8.0 so I can't do the conversion.
Thanks in advance.
Thank you very much!
