Hi, can someone help me by converting these old version of file (05 files) so I can open it in Mathcad Prime?
My option to convert the file is also grayed out. thanks!!
Please find it in attachment.
Works fine, thank you very much.
You're welcome.
Converted using PTC Mathcad Prime 8.
Starting with PTC Mathcad Prime 7, you don't need a license of legacy Mathcad to convert legacy worksheets, provided you installed the converter tool when you installed PTC Mathcad Prime 7 or 8. It's a separate checkbox that is unchecked by default. If you didn't check it, you can reinstall Mathcad Prime to do so.
I only have Mathcad Prime 6,0,0,0 and the converter is also installed but it requires Mathcad 15 software also to be installed for conversion!
