Convert xmcd files to mcdx
DD_11656061
2-Explorer
Good afternoon,
I was trying to convert an .xmcd file to an mcdx file, but it failed and I'm not sure why. I have used this program in the past and don't have Mathcad 15 anymore.
Can anyone help me convert this?
(To:DD_11656061)
Here is the file converted to Prime 10.
I utilizes and references a file "LRFD Equation Module.xmcd" , which you will have to convert as well. Furthermore at the upper right corner there is a link to a help file, which you also would have to provide in case you intend to use it.
I guess that the converted file may need quite some re-work to make it work as it should.
Hi @DD_11656061,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
