Hello everything,
Can you convert my file *. Xmcd in *. Mcd so I can open it under premium Mathcad 2.0.
So if a person among you to a powerful computer with more than 4 cores it may try to open my fihchier and send me a copy of the results in word document.
I thank all the forum.
Here you go. I've attached the conversion log too.
Remplace the variable Ffinf and ffinf2 by 70000 and not 10.
Thank you
If you have Prime, you already have the capability to convert Mathcad 14/15 files to Prime format.
The instructions are here:
http://blogs.ptc.com/2012/04/09/converting-your-worksheets-to-mathcad-prime-2-0-in-3-easy-steps/
no I can not, the button is grayed.
If you want I can do well it would help me thank you
What are you trying to do?
Mike
The button should not be greyed out.
You may need to re-install the program or call support.
Do you have MC15 version M010 (or higher) installed on your PC?
