Converting Mathcad 6 to Prime 7.0
MS_Short
2-Explorer
How to convert Mathcad 6.0 to Prime 7.0? I have a few older Mathcad files that needed to be converted over to Prime, files dated back from 1996.
9 REPLIES 9
BenLoosli
(To:MS_Short)
My understanding is you need to get them up to MathCAD 15 before they can be opened in MathCAD Prime.
How do you get them up to Mathcad 15?
LucMeekes
(To:MS_Short)
Using Prime 7's converter, they should convert from Mathcad 6 to Prime 7 without problem. If not, let us know.
It says "no license" in the in status column when I try to convert.
LucMeekes
(To:MS_Short)
You can only convert if you have a (fully) licensed Prime installed.
Do you have that?
And did you install the converter when you installed Prime? (Installing the converter is an option you have to tick during installation. For obscure reasons it's default is to not install the converter)
Or are you running Prime Express?
Running Prime Express.
LucMeekes
(To:MS_Short)
Then you should either:
- Get (=buy) a license for Prime, or,
- Attach your Mathcad files and ask if someone here can convert them to Prime (7).
VladimirN
(To:MS_Short)
You can attach a Zip archive with your Mathcad files here and we will convert them for you.
The converter can go a lot more back than Mathcad 15 files.
As far back as Mathcad 6? That I don't know. That's pretty far, but maybe it's possible.
https://www.youtube.com/watch?v=oDZxenznS20
The title says "Mathcad 15" but it applies to other legacy worksheets too. Upon installation of Prime 7, you had the option to install a legacy worksheet converter. If you checked that, you should be able to follow the steps in the video. If you didn't check it, you should go through the installation wizard again.
I manage the Creo and PTC Mathcad YouTube channels for PTC, as well as all PTC Mathcad marketing in general.
Do you have a lot of worksheets from legacy versions of PTC Mathcad, like Mathcad 15 (.mcd/.xmcd files), and need to convert them into PTC Mathcad Prime worksheets (.mcdx files)? This video shows you how to convert your files, including in batches, using Mathcad Prime's converter tool, and ...
