Hello everybody!
I need to create an uniform mesh, but i can't get needed form of the result. Is my approach for generation of the coordinates correct? Please see attached file for the problem.
Rosen
Rosen MITREV wrote:
Hello everybody!
Rosen
Does the attached help, Rosen?
Stuart
Rosen MITREV wrote:
Hello everybody!
Rosen
Stuart
Took some thinking, but CreateMesh function can be used.
edit: Better version (more than 2 x 2) substituted.
Stuart and Fred, thank you very much, i aprecciate your help!
Rosen
