Create a function that add each line of a matrix to each line of another matrix
Ahmed
Hi all,
Can anyone help me on this please?
I would like to create a function that add each line of a 12x6 matrix to each line of another 12x6 matrix and return a 144x6 matrix.
Ahmed
7 REPLIES 7
MihaiMoraru
(To:Ahmed)
Use the built-in stack keyword function... and you do not have to create your own function.
But since you want a 144x6 matrix (I think you would like to have a 24x6 matrix)... I think it will be better just to add your worksheet here... and to give more details.
Mihai
Thanks MihaiMoraru but I left the worksheet at the office.
The resulting matrix Z I want should be:
If I go from X(12X6) and Y(12X6)
Z1st row = X1st row+Y1st row
Z2nd row = X1st row+Y2nd row
Z12th row = X1st row+Y12th row
Z13th row = X2st row+Y1st row
Z144th row = X12th row+Y12th row
Do you see ?
Ahmed
(To:Ahmed)
Which version of Mathcad are you using?
Ahmed
(To:Werner_E)
Hi Werner Exinger
It's mathcad 14
(To:Ahmed)
Here is a quick solution for Mathcad 15 with rudimentary error handling and ORIGIN-aware
Ahmed
(To:Werner_E)
It does seem to be working, I will try this out tomorrow...
Thanks a lot Werner
regs
Ahmed
(To:Ahmed)
Thanks a lot Werner
regs
Ahmed
You are welcome.
You should be able to open the sheet with MC14 w/o problems. The question about the version was mainly Mathcad vs. Prime. Any of these can't open the file format of the other.
