Cycle mistake
РГ_7348811
2-Explorer
Cycle mistake
Hello Everybody!
I am somewhat new to Mathcad programing but I have faced with the task which required cycles in MathCAD to be solved.
The task:
i have a set of functions with the common function variable (tetta), which is defined in the interval  (0-360) with the step =1. And also I have a criterion, I need to crete a cycle which calculates my functions with variable (tetta) from 0 - 360 and the compare all function result with criterion. If it meets criterion conditions the stop calculations and return Pmud. If it does not meet criterion condition do calculation with new Pmud = Pmud + 0.01.
See the attached mathcad v14 file with comments.
Thanks in advance for your comments!
The sheet is complicated.
Can you provide some background like a reference or document you are following to aid our understanding on the problem.
Cheers
Terry
You cannot define a function with <- you must use :=.
Angles are measured in radians for trigonometric functions,  The use of deg as units is possible.
To get 0 to 360 in half a degree steps use
Enclosed is file that does not work yet but has corrections to the two issues above.
The comparison Capture3.JPGnever compares A(i) only 7
