DAE Floating Point Error
c_young
Hello all,
I read this board quite often for Mathcad help, and can usually find the assistance I need. But this time I have not been able to track down a solution to my problem, so I will post it.
I set up a DAE to calculate the position of a linkage with associated mass as the force in an actuator changes in a known manner with actuator length (defined as F.cyl in the attached file). The number of equations in the solve block becomes large because there are four links to keep track of (including the actuator).
My problem is that the Odesolver returns a floating point error and I cannot figure out why. I have tried changing the integration time to a very small value to eliminate points that may be causing the error, but it does not help.
If someone has time, please look at the attached file and provide feedback as to where I may be going wrong. Thanks!
Charlie
0 REPLIES 0
