Determine the center and radius of the circle of the triangle
ptc-6757983
I a'm a student and i need help witch task
Given a triangle defined by 3 points with coordinates
(x1, y1) (x2, y2) (x3, y3)
Determine the center and radius of the circle of the triangle. Draw a triangle on a graph and a designated
circle.
i don't understand this
sorry for bad english
RichardJ
(To:ptc-6757983)
You are being asked for one of these:
http://www.mathopenref.com/trianglecircumcircle.html
http://www.mathopenref.com/triangleincircle.html
but it's not clear from the question which one.
(To:ptc-6757983)
Looks like home work, doesn't it?
Why not show what you have done so far? If you have problems in one stage of your sheet I am sure you can get help here.
