Hi everybody,
I hope I can get some answers here, notwithstanding the fact that I am actually asking more than just a MathCAD question. I tried to put up a MathCAD-framework in order to explain my problem.
I wish to compute numerically the flow passing through a temperature-operated valve, of which I know (from supplier datasheet and measures on site),
1) the time constant tau (assuming that it is first order linear system)
2) the law giving the flow as a function of the temperature f(T) in quasi static behavior (dT/dt=0)
and I assume a certain transient of temperature, T=T(t)
A lot of time ago, when I was young
and still remembered "Control Theory 1", I would have solved this problem imediatly (maybe!). Now I am a little out of training
. Can someone point me to the answer, or eventually if not, to the right forum where to ask for help? Or even to some appropriate literature?
Sorry if I am out of subject, I looked for a MathCAD-forum on Control Theory but it does not seem to exist, so I just posted here.
Best regards
Claudio
Like the attached?
Alan
NB Odesolve doesn't like units so I've removed them. You should put them back after the ODE has been solved (though I haven't bothered in the attached).
Like the attached?
Alan
Alan
I think you have got it!
My personal background is more in the structural mechanics field, it was difficult for me...
I don't know how to thank you... you not only wrote the equation, you also provided me with the MathCAD numerical solution!!!
I'm going to play around a little with your solution, removing units and so.
Thanks a lot!
Claudio
