I have a problem with a solve block constructed in MC15. As long as I use a single input variable A the sheet works fine. However if I want to calculate the values for a changing chamber length it does not work. I assume it is something simple but I do not "see" it at this moment. Any help would be appreciated.
The solve block can't work vectorized because the answer changes with area. Turn the solve block into a function
Fred, thanks a million!
