I am using Mathcad 14 for some calculations of worm bodies.
To get the normal vectors of the flank of the worm I need to build a net with lines with a constant distance in y- and z-direction. First I determinated the top and the bottom border of the net and now I try to fill the net between these borders with points. But there is the problem. I can’t find any way to get this correctly done.
Maybe someone can take a look at it.
Kind regards
Alex
Thank you for your help, but I think it doesn't help me, or I didn't understand it.
I would like to do it with my method and I already have the y-, and z-coordinates and only need the correct x-coordinates.
Alex
