Display column vector
rrauck
2-Explorer
I defined a column vector as equal to the transpose of a 1 x 15 matrix (row vector). I verified that the column vector exists by displaying individual elements with a single subscript. I then take the transpose of this vector to get back to a row vector and it refuses to display when I type the vector name and enter =. I have verified that this works by using an example with fewer terms and it worked fine. What am I doing wrong?
wayne
(To:rrauck)
Robert,
Would be advantageous for you to submit a file with your question.
Below is picture, does something help, if not, please send a file.
7 REPLIES 7
wayne
(To:rrauck)
Robert,
rrauck
2-Explorer
(To:wayne)
You are right. I should have included a file. Here is one. I seem to have done the same things as you but mine does not work.
rrauck
2-Explorer
(To:rrauck)
It appears that my copy of Marhcad is damaged. Your example will not work on my machine.
wayne
(To:rrauck)
I did the same in your file, works fine, so you might be right. (used M15)
rrauck
2-Explorer
(To:wayne)
I reinstalled MathCad 15 and it now works as it should. The one difference I see is my row vector displays as a table rather than as a vector. Is that an optional setting or is it due to the length of the expression?
wayne
(To:rrauck)
For a specific result only, select the result
For the default for the file, select an area outside of a region
The on the menu bar: Format>Result>Display Options, change Matrix Style display
rrauck
2-Explorer
(To:wayne)
Thank you so much.
