Electric Motor Bearing Sizing
j0313
2-Explorer
Hi all,
First time user so unaware if this is the kind of problem that can be solved using this forum.
However, what I am looking to do is to create a template for bearings design and sizing on electric motors. The template will allow variables/inputs to be inserted by the user and it to then give an output of what type of bearing should be used (plain/rolling element etc.) for this type of electric motor and what size of bearings should be used.
The kind of inputs I have had in mind are load, motion, lifespan and speed but open to suggestions.
I have struggled to find info on any bearing design standards or motor design standards that would help.
Any help with this matter is greatly appreciated.
Joe
Hi
http://www.malloyelectric.com/wp-content/uploads/2013/07/Bearing-Handbook-for-Electric-Motors.pdf
Is this the type of thing you are looking for.
Cheers
Terry
Hi Terry,
Thanks for the reply, it is definetely better than what I have managed to find.
What i would be looking for would be how to basically translate this into mathcad to make it more 'user friendly'. I am looking for this template to be as simple and time saving as possible for the user where a couple of inputs can be inserted and then the recommendation made.
Joe
In the bearing manual no calculations are required it is just looking up numbers.
example enclosed.
