Electrical Engineering Challenge #9
Cornel
Find V2 voltage.
LucMeekes
(To:Cornel)
With the diode voltage Vanode versus Vcathode (and diode current Id running from anode to cathode) the diode model could be:
(Where Is is the leakage current, generally below 1 pA, k is Boltzmann's constant, e is the electron charge and T is absolute temperature, around 300 K at room.)
The capacitor current Ic depends on the voltage across it Ud, as follows:
now the diode voltage depends on the input voltage Ui as:
Ud=Uc-Ui
And finally Ic+Id=0, which leads to the differential equation:
The solution is:
Which brings in a(n integration) constant C0 (which is a voltage).
This expression can be worked to an expression for Uc:
To find C0 we use the initial condition set: at t=0, Uc=0, but also the integral is 0. So we get:
So the expression for Uc simplifies to:
With Ui known,
(where A=1 V and f=1*kHz)
the integral can be solved, but not symbolically, and then Ui  can be subtracted from it to get Ud.
Remember that Ud was defined upside-down. In fact V2 = -Ud, so we can write:
Lets take some values and plot:
We see the voltage across the capacitor Uc slowly growing more negative as time progresses. This moves V2 further above Ui.
10 REPLIES 10
Ssomething like that.something like that.omething like that.
Cornel
(To:NickKemaev)
I can also do simulation, but that's not what I'm interested in now about simulation, but how to solve the circuit analytically using mathcad.
Anyway, your simulation set-up and result is not yet right (see below - here assuming forward voltage drop of the diode = 0V):
ttokoro
(To:Cornel)
Prime 11 VDi=on=0
Prime 11 VDi=on=0.7
Using Luc's method, IS=10-15
Using Luc's method, IS=10-12
Cornel
(To:ttokoro)
Could you attached also the Mathcad Prime file (10) or some images with the entire solution?
ttokoro
(To:Cornel)
image.pngAttach pdf and P11. You can copy & paste one by one from 11 to 10.
LucMeekes
(To:Cornel)
Here is ttkoro's file in Prime 10.
ttokoro
(To:LucMeekes)
Thanks Luc.
Combo box with small values.
LucMeekes
(To:Cornel)
Ud=Uc-Ui
The solution is:
With Ui known,
Fred_Kohlhepp
23-Emerald I
(To:Cornel)
I really like Luc's solution.
But I've been hacking away using my meager knowledge and Prime Express.  Attached.
No calculation, simply a reference and a verbal description.
This is one half of a "Greinacher multiplier."
