Equation variable depending
BPP
8-Gravel
8-Gravel
Hi
I have a main equation formed by a sub equation with two variables of interest (AA and BB), plus a third (D) that can not be cleared, so I solve by iteration with the help of the Given and Find commands.
My question is whether it is possible to direct the main equation as a function of AA and BB, and according to the values ​​that take these, calculate the variable "D" per iteration. Attached is an example for clarity of the problem I have and what I want to do.
Thank you
(To:BPP)
Use vectorization.
9 REPLIES 9
MikeArmstrong
(To:BPP)
Like the attached?
(To:BPP)
The trick is to turn the whole solve block into a function.
Maybe the attached file helps.
Much neater solution, I like it.
It doesn't matter much in case of this relatively simply equation. But with a more complex solve block it sure would matter if you call the solveblock function D() just once or six times for every single value of RESP.
Good point. Even if this problem does not warrant optimisation, it is good practice to show it.
BPP
8-Gravel
8-Gravel
(To:BPP)
Many thanks to Mike and WE for their unconditional support.
BPP
8-Gravel
8-Gravel
(To:BPP)
Everything is fine when using the function, the problem occurs when I want to evaluate the function for a data matrix.
It is possible to assess the function "RESP" for a set of variables A1 and B1?
Thanks in advance
(To:BPP)
Use vectorization.
BPP
8-Gravel
8-Gravel
(To:Werner_E)
Thank you very much
