Error "Exception has been thrown by the target of an invocation" in MathCad Prime 10
��_12819876
2-Explorer
I'm doing a EDO resolution, and at the end of the resolution block I get error "Exception has been thrown by the target of an invocation"". If someone understood how to solve or the reason for this error. Thanks
You should attach the worksheet, not only a picture, and state which version of Prime you are using.
All i can see in your picture is that:
- alpha and beta are undefined.
- There appears to be a multiplication symbol (*) missing:
    - in the first differential equation, between C(s) and (mu.m...)
    - in the other two DE's between D and (1+R.1), which makes D seem like a function.
For alpha=beta=1, I get:
Thanks a lot, the error was due to 3 missing multiplication symbol. Thank you very much
